  #1
Old March 29th, 2009, 07:31 PM
smartboy1 smartboy1 is offline
Default shifter stuck in forward 1967 6hp evinrude fisherman
I have a 1967 (6702D C551215) 6 hp evinrude fisherman. I have the gearbox removed and it looks good, I can't get the exhaust housing to drop from the engine base plate. Do I have to remove the powerhead to get access to the shifter as it don't have a disconnect plate?, for the upper andlower shifter.
  #2
Old March 29th, 2009, 07:56 PM
a70eliminator a70eliminator is offline
Default Re: shifter stuck in forward 1967 6hp evinrude fisherman
I just went through an evinrude fisherman total r&r over this winter and yes you do have to remove the powerhead to get at the shift rod so you'll need a new gasket.
  #3
Old March 29th, 2009, 09:27 PM
F_R F_R is offline
Hold on, you don't have to remove the powerhead on about 1965-up. There is a shift rod disconnect in the gap when you lower the gearcase about 3/4"
However, to get it down that far, the seal drive pin in the drive shaft has to align with a slot. Revove the spark plugs, then slowly rotate flywheel till pin aligns with slot and gearcase drops down. Then disconnect shift rod and remove gearcase. Note the position of the pin so you can put it back the same way for ease of reinstallation. And don't turn the flywheel while the gearcase is off. Doing that, it will slide right up into place.
You do NOT have to remove the pin from the shaft to get the pump off. Merely pull the shaft out of the gearcase. It will slide right back in.
  #4
Old March 30th, 2009, 04:03 AM
Thanks FR I sure hope my bad advise didn't cause this guy and extra headache, I did not know the latter ones were that different and mine was an earlier model. I should have know better.
  #5
Old March 30th, 2009, 08:04 AM
F_R F_R is offline
That's ok, I don't know if we answered his question or not anyway. Sort of confusing, he said he has the gearcase removed and it looks good. Sounds like he is trying to get access to the upper shift rod. If that is the question, yes the powerhead has to be removed.
  #6
Old July 23rd, 2009, 03:53 PM
wiskeshdeh wiskeshdeh is offline
Default Re: shifter stuck in forward 1969 60hp evinrude skeeter
shifter stuck in forward 1969 60hp evinrude skeeter how do you git one out of gear
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
6HP Evinrude Fisherman no forward? Ron43 Johnson & Evinrude Outboards 5 July 28th, 2008 03:03 PM
1967 Evinrude 6hp fisherman props... crotter Prop Questions and Topics 0 June 22nd, 2007 09:58 PM
1991 6hp Johnson Stuck in Forward imported_fishbum Johnson & Evinrude Outboards 7 November 13th, 2006 10:34 AM
Evinrude Fisherman 6HP marc350 Johnson & Evinrude Outboards 6 March 2nd, 2004 04:40 AM
Evinrude fisherman 6hp vulcan Johnson & Evinrude Outboards 3 June 15th, 2003 01:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
