  #1
Old March 29th, 2009, 05:31 PM
a70eliminator a70eliminator is offline
Default Gear ratio 67 60hp sportfour evinrude
Anyone know where to get this info I'm trying to figure out my theoretical speed with a 10x9-1/4 prop @ 4500 RPM. I have the non heavy duty case if it makes any difference.
I think I may have a saturated hull, but don't want to cut a hole in the fiberglass deck just yet, I still have to weigh the rig too.
I got 29 MPH on a slight chop yesterday at 4500, 16ft MFG Westfield Regal "V" with a flat bottom at the transom, semi-V ?
  #2
Old March 30th, 2009, 04:08 AM
Default Re: Gear ratio 67 60hp sportfour evinrude
ok then, anyone care to make a quess. I'm going to just mark the shaft and turn the flywheel one rev and see about what I get.
  #3
Old March 30th, 2009, 07:59 AM
F_R F_R is offline
Quote:
Hey, give us a chance. I just saw the question. The gear ratio is 20:23.
  #4
Old March 30th, 2009, 06:49 PM
Thanks for that info FR
Does this calculation sound right?
4500RPM x 9.250 (9-1/4P) = 41,625 inches per minute x 60 min = 2,497,500 inches per hour.
12 x 5,280 = 63,360 inches in a mile
2,497,500 inches per hour divided by 63,360 inches in a mile = 39.41 MPH
Thats for a 1:1 ratio but we have a 20:23 ratio so now what?
39.41 divided by 1.15 = 34.26 MPH - prop slip ???
Is this all right for a theoretical speed ? and how much prop slip average?
  #5
Old March 30th, 2009, 07:16 PM
F_R F_R is offline
I didn't go through the numbers, but the theory sounds right. And the final result sounds about right too.
The theory of screw propulsion is sort of a myth. It just doesn't happen. As I understand it, and I'm no engineer, the prop acts like a pump, moving water to the rear. Every action has an equal and opposite reaction. The equal and opposite reaction pushes the boat forward. It is how a jet boat works too, they just moved the pump. It's related to the reason a rocket has thrust in space.
  #6
Old March 30th, 2009, 07:39 PM
Well, I found a prop vs speed calcualtor and the numbers I'm getting are right in there, I was clipping along at about 29MPH @ 4500R's and with my 20:23 ratio it worked out to 12% slip.
Just thought a 16' boat should be faster with a 60hp but I guess not because even if it was a 100hp the rpm vs pitch & speed would still be the same in theory.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 evinrude sportfour 60hp prop parts Zeph Johnson & Evinrude Outboards 4 January 18th, 2009 03:39 PM
67 Evinrude 60hp Sportfour Coil? jstaylor44 Johnson & Evinrude Outboards 1 July 29th, 2008 08:09 PM
'67 Evinrude Sportfour 60HP gas/oil mixture? jstaylor44 Johnson & Evinrude Outboards 1 June 19th, 2008 07:58 PM
1967 Evinrude 60hp Sportfour lower unit Zeph Johnson & Evinrude Outboards 3 March 31st, 2008 08:27 AM
'67 60HP Evinrude SportFour adding Tach? statzk Johnson & Evinrude Outboards 1 November 7th, 2007 11:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
