35 hp
fitter
I have a 35 hp merc and wondering if it would even get a 18 Ft glass boat up on plane anyone have any suggestions. I know it will at least push this thing but i dont want to blow it up in the process.
tashasdaddy
Re: 35 hp
depends on what type boat it is. more info, picture of the boat.
mthieme
Re: 35 hp
It should get it up on plane, but obviously it will be underpowered especially after you load her up. You might have to reprop her for the situation.
Loaded, I'm in that weight range with my 14' McKee which has a 35 Merc on the back (see avatar). She moves quite well.
fitter
Re: 35 hp
thanks for the info. what type of prop should i get?
mthieme
Re: 35 hp
I'm running a 15P on mine.
Of course, you need to measure rpm to get an accurate idea.
I'd try it out before doing anything.
fitter
Re: 35 hp
thanks for that . yeah i dont expect to burn up the water i just want to get to the fish at this point. knowing its a 17'8" long boat and all fiberglass weighing as much as it does i just dont want to blow this 35merc up. i will defintely give it a shot to see thanks again.
