  #1
Old March 28th, 2009, 10:59 AM
siebertl siebertl is offline
Default mariner 50 no idle; climbing rpms; have to smash primer bulb
I have an 80 something mariner 50 horse. I replaced all the rubber in both carbs. Did not look at needle valves on floats though.
Engine starts fine and runs at full throttle out of gear. But not at proper rpm. When I try to idle it dies. I got mad the other day and squeezed the **** out of the primer bulb, till i had fuel spewing out of the carbs. Started it and it ran like a champ!!!!
After fishing for an hour I started it again w/out priming. RPMs will climb and then all is fine.
Why would smashing the primer bulb fix the problem? Is there a needle stuck somewhere? Why does the rpm climb?
  #2
Old March 28th, 2009, 12:34 PM
matt9923 matt9923 is offline
Default Re: mariner 50 no idle; climbing rpms; have to smash primer bulb
Maybe some dirt in the fuel system or something and when you smashed the bulb it moved. I would buy a fuel pump kit. Their cheep. Then blow out all the fuel lines.
Are you saying it is running fine now?
Matt
  #3
Old March 28th, 2009, 01:27 PM
No, it isn't really running right. I can get it to run right if I pump the heck out of the bulb. She'll fire and idle fine. If I shut it down for an hour or so and restart at fill throttle, it will start and slowly climb in rpm, then it will idle fine.
If I let sit for a couple days, I will have to pump the ball hard again in order to get it to idle right.
Where is the fuel pump located, I thought I replaced the diaphram fuel pumps in the carbs.
Just went out and pumped the primer bulb, It sounds like there is air in the system and eventually fuel will squirt out of the top of the lower carburator. What is that port anyway?
  #4
Old March 28th, 2009, 03:48 PM
CharlieB CharlieB is offline
Rubber in the carbs?
Sounds as tho this is the model that each carb has its own fuel pump.
Squeezing the primer and fuel coming out the vent of the lower card indicates the float needle is not sealing and the carb is flooding, richening the mixture and causing the fast idle.
Once the needle seals then the fuel level lowers to normal and the motor idles.
Clean both carbs COMPLETELY, carefully check float height settings.
It wouldn't be a bad idea to go ahead and replace the float needles on both carbs while you have them apart, just to be sure that they seal properly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loss of power only around 3500 RPMs, pumping primer bulb relieves it tomfsu Mercury & Mariner Outboards 5 February 5th, 2009 08:06 PM
Temp climbing at idle speed crazy charlie Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 20th, 2006 01:59 PM
primer bulb collapsing 88 mariner magnum II jodybob Mercury & Mariner Outboards 2 September 20th, 2005 04:47 AM
Climbing rpms - A Puzzler?? Solittle Johnson & Evinrude Outboards 3 May 25th, 2005 07:18 PM
89 Mariner 135 primer bulb soft & stalling OKOKOK Mercury & Mariner Outboards 10 May 7th, 2005 12:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
