Re: Mercury Force 1996 115 Tachometer not working
Ussually a dead tach is caused by a bad rectifier.
Check battery voltage with engine OFF then again running at 2000 RPM or more while on the water. I don't recommend testing on the hose, most will not supply adequate water flow.
If battery voltage does not rise then remove the rectifier and ohms test each yellow to the red then reverse polarity of your leads and test again. The grey wire is your tach trigger.
You should have continuity in one direction y/r but not the reverse.
Post your results.
