dukhntr4lfe
- Feb 11, 2009
- 12
wow first post and im asking for a lot well i have a 69 evinrude fisherman 6hp that i got from my grandpa..... after it sat at least ten years i started it up to my surprize it started the 3rd pull... idled great went into forward and reverse great noticed that it wasnt spitting water turned it off.... started to take it apart and noticed some things wrong heres what i have to replace...
main spring-rewind and the pinion
water tube grommet
water pump thinking of getting the kit
impeller repair kit
hopefully that will be a start i also need to check the water tube to make sure its not clogged
im pretty mechanically inclined and if i run into probs my buddys is a boat mechanic
just wnt to kno wif you think its worth it to do this and any problems i might run into
thanks
water tube grommet
impeller repair kit
thanks
