  #1
Old March 27th, 2009, 03:06 PM
jwbergeron jwbergeron is offline
Default Tilt Cylinder Disassembly - 1998 Yamaha 250
Fellas,
I need help with the tilt cylinder assembly. I have all new O-rings & seals to replace, but cannot figure out for the life of me how to get the plunger off the end of the shaft (which would allow me to replace all the seals).
I have the subassemby out laying on the bench...that was a piece of cake. There's a very small roll pin in one side of the plunger that looks like it could be locking it on... Anyway, I stopped before I broke something.
See attached pic of the part. Thanks for your help!
  #2
Old March 27th, 2009, 07:39 PM
rodbolt rodbolt is offline
Default Re: Tilt Cylinder Disassembly - 1998 Yamaha 250
dont do anything yet.
I actually have a 61A unit on the bench.
let me pull it apart and Ill post what I find.
its a scrap unit that I was showing our recent newhire(the MMI graduate) a bit about.
  #3
Old March 27th, 2009, 08:03 PM
ok
just did it.
to dissasemble the piston from the shaft lock the tilt pin end in a vice and using a strap wrench, nothing metalic, unscrew the piston from the shaft.
if you remove the #30 torx screw holding the piston springs and check balls in place remove them for cleaning and it may be possible to use a pin type spanner to unscrew the piston from the shaft.
  #4
Old March 27th, 2009, 11:39 PM
Bingo. Rodbolt, you are a magician! I used the spanner wrench in the spring hole method you suggested. I bought a nice adjustable metric spanner wrench kit from Grainger that works for all this stuff for about $60.
Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 Yamaha HPDI 250 - Not Firing in #2 & #3 Cylinder GWDolphin25 Yamaha & Suzuki Outboards 2 September 7th, 2008 02:20 PM
250 yamaha trim tilt fishegle Yamaha & Suzuki Outboards 1 June 13th, 2007 09:22 PM
tilt cylinder disassembly 87lundtyee Mercury & Mariner Outboards 0 May 11th, 2006 07:42 PM
1998 Yamaha 250 OX66 jwbergeron Yamaha & Suzuki Outboards 3 April 5th, 2006 02:38 PM
Trim Cylinder Disassembly DavidT Yamaha & Suzuki Outboards 0 September 20th, 2001 08:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
