nastyquedawg
- Dec 25, 2008
- 89
I took my Weldbilt 1652 Jon Boat out last Saturday and was questionable about it's performance. Prior to Saturday, I had not ran the motor since Sept 2008. I ran all the gas out of the carb before putting it up. In the past, I was able to get my boat to go 19mph with 2 adults and on Saturday I was only able to get about 13mph with the wind at my back. When I was priming the motor I noticed brown colored fuel, so I drained it off until I got to the fresh fuel. I beileve some of that brown fuel got into the carbs. I assume that it was the gas left in the fuel line. After the fresh gas got to the motor it started on the 3rd pull and it idled fine. When I put it in gear I felt that it could not achieve WOT. I have since added some seafoam to my gas in hopes that next time I run it it would improve the performance by cleaning the carb. Is there anything else I should do that does not require me to disassemble the carb. Also it is time for a new water pump and a lower unit oil change, will this hinder performance also? Thanks in advance for your responses, I love this site.
