  #1
Old March 26th, 2009, 08:03 PM
dolphinhunter dolphinhunter is offline
Default 93 Mariner 115 carb issue
Hey guys the problem i seem to have is that the carbs seem to be dumping way too much fuel into the motor. i cleaned the carbs about a week ago and it ran fine. i had to fiddle with the trim today cause of an air bubble than after i got that sorted out i tried to run it but it's dumping a lot of fuel out of the exhaust. i let it sit then came back to it and it ran well but still a little rich and all i did was pull the cover off the carbs to see if i could see any of them dumping a lot of gas into the motor. you guys have any suggestions or do i have to pull the carbs apart again and make sure a float isn't stuck or something like that.
thanks
  #2
Old March 26th, 2009, 08:49 PM
Laddies Laddies is offline
Default Re: 93 Mariner 115 carb issue
It could have picked up some crude or it may need new inlet needles if you didn't do it the first time.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old March 26th, 2009, 09:27 PM
shes a keeper shes a keeper is offline
had the same problem with my merc115 same as mariner did you take the floats out and make sure no holes in the floats? and did you change the inlet needles if not make sure they are set properly and clean mercs and mariners seam to have tempermental issues with microbes(hope spelling is correct) :
  #4
Old March 27th, 2009, 10:28 AM
Chris1956 Chris1956 is offline
inspect the fuel pump. If the diaghram springs a leak raw fuel will be dumped into the crankcase, and from there into the water.
  #5
Old March 27th, 2009, 10:37 AM
the fuel pump seems oddly right when i pulled the fuel line while it was acting dumb it ran normal until it ran out of gas. i'll take a look. and if that's not it i'll be ordering new carb guts today.
  #6
Old March 30th, 2009, 07:58 PM
I figured it out. My key switch is bad and it's causing the primer solenoid to hold open pumping an insane amount of fuel into the intake. Go figure i started to blame myself first.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Mariner 115 electrical issue? davidf5252 Mercury & Mariner Outboards 3 July 2nd, 2008 04:08 PM
25 Mariner Carb issue barroomhero Mercury & Mariner Outboards 2 May 29th, 2007 12:44 AM
95 Mariner, 25hp carb issue - need help bostie007 Mercury & Mariner Outboards 8 July 30th, 2005 05:06 AM
93 115 mariner questions tnastro Mercury & Mariner Outboards 1 May 29th, 2005 07:41 PM
93, 115 Mariner johnnybigrigger Mercury & Mariner Outboards 5 January 16th, 2004 04:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
