Corrosion inside water passages of Alpha drive
jy118lfd
On my 1999 Alpha gen 2 5.0L I noticed inside the gimbal housing and upper unit There is some corrosion pits in the aluminum. In the upper unit I scraped the corrosion and the hole was about 1/4 inch deep. Pics below. The drive is about 1 inch thick here but I am a little concerned. In the gimbal housing the divots (3 small ones) are about 1/8 inch deep. Anyone ever see this? How can I treat the aluminum to stop or slow the corrosion?
JustJason
Re: Corrosion inside water passages of Alpha drive
welcome to the world of salt.
The best thing you could to if your willing to take a bit of time is to sand that flat with some 400 grit and a sanding block. After its smooth and clean... prime it, sand it, prime it, sand it, clean it, paint it, sand it, clean it, paint it..... after that put a little perfect seal on the 0 ring that seals that opening.
jy118lfd
Yea unfortunatly I know all about the brine. I just could not for the life of me understand why the inside looks like that and there is no corosion on the outside of my drive. I have wet slipped the boat for 5 years and its in mostly fresh as I am way up the river. I just wondered how many years I will have left before it gives me a problem.
jy118lfd
Its not so much the sealing area but the divot inside the passage.
JustJason
kinda tough to tell from the pics.... but isn't that the water passage in the upper that your posting?
jy118lfd
Yes that is the upper. I did not get a pic of the gimbal housing. The gimbal housing is not nearly that bad.
