  #1
Old March 25th, 2009, 04:08 PM
Jethros Jethros is offline
Default 2002 yamaha 60hp hard starting
I prime the fuel bulb tight but when i go to start it take about 30 seconds to start. Once it started it runs for a lil bit idle and then stalls. Starts right up again but wont idle long. What do you think is the problem?
  #2
Old March 26th, 2009, 02:31 PM
bullbat bullbat is offline
Default Re: 2002 yamaha 60hp hard starting
2 stroke, 4 stroke? does the bubble lose prime? can u squeeze the bubble and it stay runnin, does the choke work? are u runnin a fuel filter, if so is it clean?
__________________
1994 Astro S-15B w/ 1977 1150 merc
  #3
Old March 26th, 2009, 04:24 PM
it is a 2 stroke and i notice that it will losethe gas back flow back to tank I think Is it supposed to require a prime 3 hours after its been off? The choke seems to work on compression I have 125 on top 2 and 98 psi on the lower cylinder. Once it starts it smokes a bit like more flooding. I thought i flushed out the filter good but maybe it had a lil more crap in it after cleaning the carbs
  #4
Old March 26th, 2009, 04:46 PM
if your are losing prime thats one problem maybe get a new bubble but the compression is another problem u should have no more than a 10% diff in the cylinders you may can try to do a decarb with sefoam and see if it gets that compression back up on the #3 cylinder. but other than that sounds like u may have a bad bubble if gas is flowing back to the tank. i would get a new bubble and try to decarb the engine and see what happens then, also make sure that you have no leaks in the fuel system any where and make sure all fuel lines and connections are tight so that is cannot suck air that'll make one act stupid also
__________________
  #5
Old March 27th, 2009, 03:18 PM
Thanx for the advice! I replaced the fuel line and bulb a few minutes ago. I dont think i have a choke but an starter assy? I am getting 4 olms resistance but doesnt seem to get 12 volts to it when I turn on ignition an push key in. I did the seafoam in the tank and in the 3 venturis and reved mildly to blow out the smoke. It seems to maintain an idle to an extent but I better take it for a run for a while and see it it straitens out. Will the enrichener energize with it in the on position?
  #6
Old March 31st, 2009, 06:57 PM
anyone have any info on trouble shooting the choke on this motor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hard starting 60HP merc imported_fixit Mercury & Mariner Outboards 5 August 21st, 2007 09:13 PM
hard starting 60hp merc imported_fixit Mercury & Mariner Outboards 1 August 21st, 2007 04:56 PM
Hard Starting 2002 Merc ury 90horse onebohemian Mercury & Mariner Outboards 6 July 9th, 2004 02:27 PM
Hard starting 2002 Mercury 90 Saltwater ELPTO borskislider Mercury & Mariner Outboards 2 February 26th, 2004 05:02 AM
Yamaha 60hp hard starting manosf Yamaha & Suzuki Outboards 2 July 30th, 2003 04:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
