seacast-nidabond
brian3127
well i did some measuring of my transom yesterday and figured i need 11 gallons of seacat. (small transom) so thats comes out to be about $550 shipped. then i looked at nidabond. if their bucket are 5 gallons then i would save about half. but i have read that you have to get your own hardener MEKP. i have no idea where i could get this stuff from here in michigan. or how much it cost. the seacast has everything you need.
jonesg
Re: seacast-nidabond
gET CATALYST AT ACE HARDWARE STORE OR ORDER FROM ANY RESIN SUPPLIER, You'll have to pay the enviroment shipping fee .
But its not hard to come by.
I used seacast, wish I had known about the nida.
Get a 16 inch elec chainsaw. Works a treat.
brian3127
is this stuff easy to use
jonesg
very simple, its a non event when you come to the pour.
Its all in the prep.
Remove all hardware and thru bolts/fittings, remove wood, clean, blow it out , tape all the holes shut and you're set to go.
brian3127
well i ordered the seacast instead of the nida core. i only needed 11 gallons and seacast had five gallon pails and one gallon pails. nida core only had 5 gallon pails.
so for the nida core 3-5 gallon pails shipped came out to be $547.37. that is without the catylist(spelling)
seacast i got 2-5 gallon pails and a 1 gallon pail for $548.67 shipped and i dont need to get my own catylist. everything you need comes in the kit.
seacast also said that nida core doesnt have a live support line to call if you have any ?'s. it should be here in about 2 weeks. cant wait to get started.
