When I got my air compressor many years ago I got an unrestricted air gun. It lasted many years and finally gave out. All I see now are these OSHA restricted guns which limit the pressure. Any idea where I can get one of the old unrestricted ones?
Thats it, i am so used to fixing my own tools, i don't even think about it, drills and such, just second nature i guess.
Drills i just take apart and fix the trigger, cause most of he time it's just a connection, or electric motors most times the ends of the wiring is rusted and just a snip and adjustment it's good to go another 10 years.
solittle said:When I got my air compressor many years ago I got an unrestricted air gun. It lasted many years and finally gave out. All I see now are these OSHA restricted guns which limit the pressure. Any idea where I can get one of the old unrestricted ones?
.The reason that OSHA restricted the guns was so that if you stuck in to your skin and pulled the trigger, you could not introduce air into your bloodstream through your skin. The blowguns that we use at my shop are still the same volume and pressure, but there is a conical tip that extends past the orifice so that you can't seal it against your skin. I think they actually move more air than our non-OSHA blow guns. I will look up the brand and model at work and post that up if you want.
