Likely you have a commander 2000. my 1989 60hp is equipped with the same.it is all black,with a fast idle lever,with trim switch optional.you ought to look inside yours before investing top dollars for a new one,and all the other work involved in swapping over. a good parts listing is from dougrussell.com,
http://dougrussell.com/partscatalog/...6,39,40,5,27,0 if the link doesnt work just go to the site and search parts catalog,then quicksilver,then remote controls and look for the 2000,all the others are on there also,so if you have a different model you will see that also. hope it helps
