SteuryLover
- Nov 19, 2008
- 191
Well on top of my other other issues which are being handled in another thread, I am having lower unit problems.
Last week when cruising around, I noticed I had a hard time finding neutral. I had no issues finding reverse or forward. But I would have to play a little at time to get neutral. So I decided to adjust the trunnion to see if it was a simple adjustment. After a small adjustment I now had good neutral, good forward but when I went to reverse the outboard would rev before the gears would change. so I adjusted the other way a little, now got the opposite effect. Reverse no problem, easy neutral and revs before forward gear would engage. The RPMs would get over 2k before it wanted to engage. So I was able to play with it and get it to an acceptable position.
I got it out of the water and tried to pull the drain and vent screws, but am having a problem with them. The last shop I brought it to said they put them on with an impact gun. I tried my impact to tack them out with no luck. I loose grip before they spin, so any help getting this out would be great. Any tricks to getting them out is appreciated. Once I get them out I can get a better idea of metal and fluid color. Other then that what else should I do? What else would cause this? The cable seems to be fairly new and it seems to shift the shift rod correctly. Any help is greatly appreciated, thanks again for all the help.
