Read the manual. Oil level or flow problem.Blowing good smoke, good water,motor cool . Oil level good.Made no difference with connector pulled.Removed the tank level indicator and checked it for cleanliness anyway.Tried a continuity test on the level indicator but no continuity high or low. Must require oil to make the connection.
Pulled connector from VRO, beeping stopped. Replaced the Pulse limiter. Still the same.Sure would appreciate some ideas on this. Hope its not the VRO but I know there are problems with them. Am running the clear tube test so I know that oil is being used. Can't tell if its enough because I cant feel the pulses in the fuel output line as recommended. Plenty of oil coming out of the tank line.
On a positive note the sun is shining here and its warm again at last.
