I have 96'C60 yamaha the plugs always have oil on them when I pull them but they are clean with a little carbon its somewhat hard to crank when its been sitting up I put NGK plugs with a resistor should I change them with non resistor plugs and I run a gutted thermostat also what is causing the oil on the plugs.Im new here and sory for the long post.I run quicksilver oil and prem fuel.
