OK, I bought early 80s Mercruiser 260 and found out it has a dropped exhaust valve. I took the head off and the piston will definitely need replaced. I'm taking the other side off tomorrow to get a valve job done on the heads. If the other 4 pistons look as good as the three on the starboard side would it be safe to just replace the one piston and is there anything else I should look for before I dump any money into this engine? By the serial number on the valve covers it is indicating a 80 or 82 350 but by the exhaust manifolds it is indicating after 82 as this does not have the log type manifolds but the elbow comes off the center of the manifold. What ya all think?
