I have a 12 ft Simple Aluminum slight V-Hull boat, and want to use this boat to run up river, this river can get quite a current when water is running. So what size engine would have enough power to get up a fast current? I was looking for a 9.9 hp, but I wonder if a 6 would be able to do the job?
the boat is very light, maybe 200 lbs. And the beam is about 3-4 ft wide. closer to 4 ft wide.
__________________
16 ft runabout w/ 70 hp evinrude
Re: What size motor for 12 ft V-hull Aluminum boat?
This is the Susquehanna river, at the Head of the Chesapeake bay. It is about a mile wide, But there is a dam upriver, and when they release water, it may be a 5 MPH current, maybe more.
I had a 2 50 lb thrust trolling motor's on there, and had both going and was just staying still in the current.
__________________
9.9, definitely.
For trolling motors you can guess at about 1hp for every 25- 35 "pounds of thrust."
It's actually not that simple, and I think there is a thread somewhere about the math, but that is good enough for easy figuring.
So a 6hp will just barely creep you over the speed of the current. It may not plane your boat well, either, but I have no reason to say that other than a guess. You will likely plane out about 10 to 15-ish mph with the 9.9, nice for getting somewhere and enough to insure a margin of safety.
That is my opinion. Mileage may vary...
__________________
Clean feet are happy feet; same for boats.
1964 MFG Niagara Deluxe
Almost all v-hull 12' boats are rated for 10 hp, so I'd get the 9.9. It'll plane you out, and that's the key to going upriver. With the six, not so much. I use my 6hp on the Mississippi, though, up here in Minnesota. I avoid the river when there's a lot of current, since it's a drag running against it.
__________________
Sure...go ahead and laugh at my old aluminum boat. It's paid for!
least 9.9 i got a 10hp 2 stroke and with me and buddy about 135 and 110-115between the both fo us and some gear plug gas we plane out pretty good if he sat in the front. my boat was a flat though with a vi hull in front. would suggust leats 9.9
I have a 12' Duranautic V hull, it runs along ok with a 1978 6 hp Johnson on it but struggles in anything but the very least amount of current with two passengers. I'm close to 300lbs, and add a passenger and some tackle, and were pushing 600lbs, it moves the boat but not very fast. My 9.9 does a lot better but still isn't super fast. I actually do better with my older 9.5 hp Evinrude since its so much lighter and I don't need to carry the 75lb battery.
I have a Honda 10hp, it's an older Honda 100 4 stroke, it runs great but outweighs my Johnson 25 hp. I wouldn't even consider hanging it on my 12' boat. I believe their 7.5 hp motor is based on the same motor?
I'd go with no less than the 9.9 hp. The best thing I did to mine was to put the 15hp carb on my 9.9, that woke the motor up enough so it at least has enough power to get the boat well on plane and moving along at a nice pace.
My Duranautic is rated for 10hp max and 540lbs.
Hello
What is the motor rating for the boat?
I have an old 12ft sears V hull--It is only rated for a 7 1/2 HP
I have a Suzuki 6 HP on it.It is all the motor I want on it. Once in a while I use it up in maine on a river with a strong tidal flow.It seems to handle the
currant OK.
Quote:
Originally Posted by bowman316
yea, 4-strokes are way too complicated for that size of engine. And too much weight.
I replaced a Johnson 9.9 with a Honda BF100 (10hp, 4 stroke).
Weighs 75 pounds. Heavier than the 9.9 but still light enough that it was easy to use and I much preferred it over the 2 stroke, especially for trolling.
I could plane out my 12 foot (rated for 10hp) and hit 26kmh (gps).
The old blue and white Honda's are great motors, require little added maintenance and are not that much heavier. If you are choosing between a 6hp and the Honda 7.5, I'd go with the Honda.
But I do think you need a 9.9. Take a look at the old Honda's before deciding.
I bolted a 1976 20hp mercury on my 12 ft aluminum boat, and I find it gives me just the right performance...the boat did give up its own name....
ITZA HANDFULL
I had just about the same boat. 12 footer, 3-4 feet wide, and not real deep. I had a 6hp Merc on it and it would not plane unless I sat in the center seat and extended the tiller. Then it was fine, but not real convenient. Go with a 9.9 it should do the job.
By the way I weigh about 200lbs if that helps explain/judge the planing & moving up to the center seat issue.
