Re: what prop for pontoon??
I can tell you right now you will need less pitch, because a pontoon is a lot different than a bass boat.
You might not even be able to plane with that prop, but Go see, and depending on your rpm's you may need to go to a 12 or even a 10.
Every inch you drop in pitch adds 200 rpm's.
__________________
16 ft runabout w/ 70 hp evinrude
