mercury 115 1972
glazen82
hello i have merc 115 that willn't start. there is spark in all cylinders. when i check the plugs after trying to start 1 cylinder is wet 2-6 are dry. are the fuel pumps bad. thank you for your help.
Laddies
Banned
Re: mercury 115 1972
Probably not or fuel would be coming out the exhaust. Did it just quit, and give a little history on the engine and problem.
glazen82
the motor was run fine than go back the ramp it shut off. took cover off the wires to the distributor. broken they were crowed . up inside dist. body. i got another dist. there i spark in all cylinders middle carb floods out the front.
Laddies
Banned
If it was running till you changed the dist. I would think the dist. is the problem, it is either not in time or the cap thats on it does not have the spark plug wires installed to match the firing order of your engine.
glazen82
laddie thank you for your information. i haven't tried it yet will let you know.thanks again. glazen82
