  #1
Old March 21st, 2009, 02:53 PM
bob johnson bob johnson is offline
Default yamaha 115 compression question
I was given a 1987 2 stroke 115 hp yamaha motor and I figured Id check the compression and check the spark....thinking it might have had problems...
since it was free!!
anyway the compression was 140 in all 4 cylinders...it is a 2 stroke V4.
but on one cylinder the pressure in the screwed in compression gauge started falling right away . after maybe15 seconds it was less than half of what it started at.
i went back and checked another cylinder....and it didnt fall at all
could that just be function of where the piston stopped when I stopped cranking the motor???
ie and exhaust or intake was exposed??
it has great spark....but the lower unit is missing...and the power tilt and trim is missing.
the motor looks like it has never been worked on..( painted gaskets)
there is a build up of carbon on the piston tops when I look in the cylinders.
is it hard to find lower units for this motor? and t&t units?
thanks
bob
  #2
Old March 21st, 2009, 05:41 PM
JB's Avatar
JB JB is offline
Default Re: yamaha 115 compression question
http://www.boatmotors.com/motorparts/
__________________
RED SKY at night. . .
JB
  #3
Old March 21st, 2009, 06:05 PM
triumphrick's Avatar
triumphrick triumphrick is offline
I'm not too sure of your gauge, but of those I have used the pressure has to be released manually. I usually crank for about 4-6 seconds and then read the gauge. All this of course after the motor has warmed up.
One more thing about that motor. Pre 1993 Yamahas had a bad habit of breaking the shift rod. They were steel and would rust in two. You can see the rod running down from the front of the powerhead towards the foot. If not replaced by a stainless rod you can get stuck. Just something to keep in mind before you venture too far.
__________________
KeyWest 2300 WA Twin Yamaha F 115's
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 yamaha 115 1.7l v4 no compression on one cylinder spud7378 Yamaha & Suzuki Outboards 1 June 27th, 2008 11:27 AM
RODBOLT or yamaha guys! Yamaha 50hp 4 stroke low compression question! oonighttrain Yamaha & Suzuki Outboards 8 January 22nd, 2008 10:19 AM
Evenrude 115 1979 Compression Question gearyg Johnson & Evinrude Outboards 4 October 1st, 2006 06:54 PM
72 115 hp Merc Compression question SHUMAKEB Mercury & Mariner Outboards 3 September 28th, 2004 08:24 PM
72 -115 hp Merc Compression question SHUMAKEB Mercury & Mariner Outboards 5 September 27th, 2004 08:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
