115 Mariner 2 stroke 4 cyl outboard...# OD211932 ( 93 ' I think )
PROBLEM :
Tilt trim moves motor either UP or DOWN BUT NOT BOTH WAYS....
WHAT I HAVE DONE:
Relays have been checked and are OK
Replaced the brushes on the motor recently
Replaced manual release valve/screw
Brand new battery
MY STORY :
I've been forced to use the Manual Release valve to tilt the motor UP so I can get it out of the water...I've done this a half dozen times due to issues w/ the tilt trim...my mechanic said to replace the manual release valve and top up the fluid for starters...I've done both.
Here's the odd part...when I adjust the valve one way (counterclockwise) the motor will go UP but not DOWN....if I rotate the valve the other way ( clockwise) about a full turn, the motor will then go DOWN but not UP.
Is there some magical spot where that valve need to be set ??
My reasoning is the motor and electrical are ok ( motor will travel both up and down ) and that I've buggered up the hydraulics somehow by using the manual release valve....
Or is this indicitave of another issue ?
cheers
Greg
PROBLEM :
WHAT I HAVE DONE:
Brand new battery
MY STORY :
cheers
Greg
