I have two batteries wired parallel.Currently unhooking them at the terminal,to break the circuit after charging.(that what I was told to do?)
Thinking of buying a switch but without an outboard not sure where to connect the negative wire.
http://forums.iboats.com/attachment.php?attachmentid=22481&stc=1&d=1233283458
I have no fuse panel,buzz bar or common ground,other than the negative terminals on the batteries.
Does the negative go to the com position on the switch?
Couldn't find the answer in the search...sorry if it's here somewhere.
