A lot of folks seem to think that a voltmeter can't be used to determine the true charge state of your battery. I say it can and here's a guide that will let you do it. These are the standards that battery manufacturers set for their batteries and the same standard that is used to calibrate the light bars like your trolling motor might have built in.
I tried a couple of times to format this as a table but it didn't work. I'll post the link to wikipedia that has the same info instead:
http://en.wikipedia.org/wiki/Car_battery
- Quiescent (open-circuit) voltage at full charge: 12.6 V (100% Charged)
- Unloading-end: 11.8 V (60% Charged - 0% usable charge remaining)
- Charge with 13.2?14.4 V
- Gassing voltage: 14.4 V
- Continuous-preservation charge with max. 13.2 V
- After full charge the terminal voltage will drop quickly to 13.2 V and then slowly to 12.6 V
- Wait at least 12 hours after charging to measure open circuit voltage, the resting time allows surface charge to dissipate and enables a more accurate reading.
