  #1
Old March 20th, 2009, 08:02 AM
Jabbahut Jabbahut is offline
Default 1996 200 hp Mercury Stator
I am having my 1996 merc 200 hp stator replaced because when I was running the engine it would speed up and then go back to normal or jerk and not stay running. The repair guy told me the mercury stator cost $500.00 dollars for this motor. I did a check around and could not find a stator costing this much. AM I BEING SCAMMED? Please advise.. Thks.
  #2
Old March 20th, 2009, 09:30 AM
Laddies Laddies is online now
Default Re: 1996 200 hp Mercury Stator
That's steep unless he is installing a stator kit from Mercury.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old March 20th, 2009, 12:06 PM
CharlieB CharlieB is offline
I wouldn't get in a rush to let anyone change that stator just yet.
You said the motor SPEEDS UP then goes back to normal?
500 bucks for a stator is NOT going to cure your problem.
A failing stator will LOWER RPM and recover, not speed up.
Your problem sounds more like a restricted fuel supply or an intermittent intake air leak leaning the fuel mixture out, speeding up the motor, and soon to melt pistons if not diagnosed and repaired correctly.
It is also possible that an ignition module is intermittently advancing ignition timing. Proper testing will prove any ignition fault.
Throwing expensive NON-returnable NON-refundable ignition parts at a problem will only seriously lighten your wallet, without fixing your problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Mercury 120 xr jet drive Stator Electronic question. Can someone please answer gpshogan Mercury & Mariner Outboards 1 July 28th, 2008 06:03 PM
1996 Mercury 200 EFI rambilt Mercury & Mariner Outboards 5 April 9th, 2008 07:36 PM
1996 200 HP Mercury Lower Unit or linkage Adj. Problem jorwalke Mercury & Mariner Outboards 1 January 20th, 2005 07:16 AM
Mercury 200 Optimax Sportjet jet pump stator damage NW Cajun Boat Topics and Questions (not engine topics) 0 April 19th, 2004 02:20 PM
1996 200 hp fuel infected mercury rdevane Mercury & Mariner Outboards 0 May 13th, 2002 07:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
