fishjefffish
- Jan 26, 2009
- 22
I have a 1973 Mercury 650, 3 cylinder. 2 cylinders are a little lower on compression. Ring job coming in the future??? Are there any fuel additives to help in the mean-time?
I am going to clean the carb with seafoam then add it to the fuel.
Yes it is a 2 stroke. What do you mean? The proper amount of oil to what? The gas? It is a 50-1 mixture, or to the deep creep I plan to spray in the plug holes?
The best way to do it is to use a small portable tank, add a gallon of gasoline
and 2.6 oz of 2 cycle oil so you have a 50:1 fuel mix. Add a can of Sea foam.
