Re: Lower Unit Loose but Stuck!
could be where your main shaft splines slip into the crank splines have some corrosion and have siezed. might seperate with some WD-40 penetrant, or it might be similar to my experience with an old blue band Mercury, where I had to cut the leg off with a angle grinder(lucky to have a spare leg) weld a slide hammer to what was left of the shaft, apply heat with an oxy torch, and smack it like hell for 15 mins until it came out, and there was nothing left of the splines on either shaft or crank(corroded)
But between the WD-40 and the slide hammer I had tried tipping the engine upside down and letting the area soak in a puddle WD-40 for a week, diesel for a week' then took it to a boat shop where they had a press set up to split them and that didnt work
So who knows it might come easy, or it might be a boat anchor
