  #1
Old March 18th, 2009, 10:05 PM
Oday Sailor Oday Sailor is offline
Unhappy 200x Evinrude 9.9 Electric Start Wiring Question
Hi all, hope you can help me out:
I have a 9.9 Evinrude Electric Start motor. I believe it is either 2000 or 2001.
The motor only starts manually, with the pull start. I cannot start the motor using the key - I turn the key, but nothing happens. I've checked the battery and the cables, spark plugs, all that stuff is fine. If I manually start the motor and then turn the key on the electric start to OFF, the motor does shut down.
I connect the positive and the negative lead cables from the motor to the battery. I am attaching a picture of the electric start module - with the main question. Should I connect something else to the battery? There is one silver prong that is left unused on the electric starter. Is that supposed to be unused, or should I be connecting something to it? I tried to connect it to ground, but still nothing happens.
Would be happy to provide any other details if they might help. Thank you!!!!
  #2
Old March 20th, 2009, 07:40 PM
skyking.5 skyking.5 is offline
Default Re: 200x Evinrude 9.9 Electric Start Wiring Question
Check the Neutral Safety Switch
  #3
Old March 21st, 2009, 12:15 PM
I'm sorry - I'm a bit new to this: do you mean that extra prong gets connected to the Negative on the battery? I did try that, however, same result....
  #4
Old March 21st, 2009, 12:26 PM
CATransplant's Avatar
CATransplant CATransplant is offline
Uh...no, that isn't what he meant. Don't start connecting things willy-nilly. You could easily destroy some expensive parts. Instead, start looking for a service manual for your outboard. I believe you can order a service manual for that late model outboard from any Evinrude dealer. It will have a wiring diagram showing the proper connnections, all color-coded.
The basics are that there should be a positive and negative battery cable coming out of your outboard. I'm assuming this is a tiller model. When those are connected to the battery, the starter should operate when the outboard is in neutral, but only then, when you operate the starter switch.
You have the switch out of the outboard. Did you remove it? If so, have you disconnected any wires at all?
__________________
Sure...go ahead and laugh at my old aluminum boat. It's paid for!
  #5
Old March 21st, 2009, 12:33 PM
OK, we're going to have to have the model number on your outboard. There are several variations. Also, is your ignition switch mounted remotely?
__________________
  #6
Old March 21st, 2009, 12:43 PM
OK, on the remote control versions, there is a 20-amp fuse in the wiring harness. It's a plug-in fuse. I don't know where it's located on your outboard, but it's under the hood. That's probably the source of your problem.
__________________
  #7
Old March 21st, 2009, 05:00 PM
Thank you guys for the quick replies...
Don't worry - I haven't connected anything randomly quite yet And yes, it is in neutral...
So - the model number is: E10TEX4SID - Electric Start 9.9 Evinrude, 2001
The electric starter part (the one in my pic) is connected to the motor via a cable.
I have tried starting the motor by turning the key, (after connecting the +/- from the motor to the +/- on the starting battery), but got nothing. No sound, no start, no clicking noise. The battery is brand new, and I even tried another battery.
The motor does start easily by pulling on the rope starter. I've checked the fuses, they were fine, I even replaced them just in case...
Went to Waste Marine today and bought me a nice $37 Johnson/Evinrude Outboard Repair Manual... Looking through it is like looking at Japanese characters to me.... Thanks for the help guys!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Honda BF15A electric start wiring routing walexa Honda & Tohatsu/Nissan Outboards 0 September 15th, 2008 11:50 AM
Wiring a '93 25hp Merc. for electric start canadales Mercury & Mariner Outboards 0 July 15th, 2008 03:30 AM
9.9 electric start wiring? mikey887 Johnson & Evinrude Outboards 3 May 8th, 2005 07:57 AM
Electric start wiring jdsm24 Johnson & Evinrude Outboards 0 August 19th, 2003 05:21 PM
1979 40 Mercury Electric Start- Wiring Harness raldin Mercury & Mariner Outboards 1 September 19th, 2002 06:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
