Tharsheblows
- Jan 26, 2009
- 4
I recently aquired a 20' 1973 Slickcraft Cuddy. The hull is in great shape and everthing is solid. I saw the boat once before I got it (cheap) and was not able to get serial #'s. It currently at a buddys shop.
From what I can tell it's an original Mercruiser inline 6 165 that is seized ~a fat guy with a socket and breaker bar on the crank couldn't budge it. The air cleaner was left off and a storm some odd while back blew the dog house off the deck. Water in turn got into the intake. The outdrive is original but had papers for the rebuild not too long ago.
My questions:
(1) would a same era style GM Merc like a 4.3, 305, or a 350 be able to "bolt up" to the outdrive? I know you can do this with car/truck motors.
(2) would it be way to much (work if even possible) or just pay to just rebuild the motor as is
I've been building hot rod motors, cramming big blocks into small cars and trucks so I am no stranger to a mechanical challenge. Then again I don't have to worry about a car sinking at the 1/8mile. I'm just wondering what might be involved in changing it out. The previous owner did state that the motor (when running) had the grunt to gettup and go, but then again he said it ran fine and shouldn't take much.
My questions:
