  #1
Old March 18th, 2009, 07:49 PM
BassSpotter BassSpotter is offline
Send a message via AIM to BassSpotter
Default Problem with fuse by solenoid on 110 1990 Evinrude
I was hoping somebody may have a little information or guidence for me. When preparing my boat for the upcoming season I noticed that I didn't have any power to my tilt/trim or to my starter. I checked over the wires and battery and found that the 20 amp fuse by the solenoid was blown. I placed a new one in and it blew. It blows as soon as the new fuse is placed in. The ignition switch is off and I checked the hot wires for wear but nothing. Any suggestions?
  #2
Old March 18th, 2009, 08:07 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Problem with fuse by solenoid on 110 1990 Evinrude
check your power trim circuit, it works when the key is off, and could be shorted.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old March 18th, 2009, 09:05 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Suggestion...... Connect a ohm meter set to hign ohms between the open fuse lead (not the one connected to the solenoid, the other end) and the powerhead (ground).
You'll obviously obtain a high reading due to a bad short, at which time you can now locate the short. When the ohm reading drops to zero, you've got it.
  #4
Old March 24th, 2009, 02:45 PM
Thanks for the info guys, after going over everything it ended being a hot wire in the red plug, I ran a jumper wire for the plugs to check and it worked perfectly. Thanks again!
  #5
Old July 5th, 2009, 12:03 PM
chriscraft amerosport 262 chriscraft amerosport 262 is offline
I have a 10 amp fuse next to my trim motor that blows as soon as I put the fuse in the holder. Is this the same problem you had? I am not sure what to do as I have searched for hours for a shorted wire.
  #6
Old July 5th, 2009, 12:46 PM
sure sounds lke it. the ignition fuse is a 20 amp.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
omc 110 engine fuse JOHNSON110 Johnson & Evinrude Outboards 14 September 19th, 2006 11:56 PM
82 evinrude ignition problem (blowing fuse) Red Rover Johnson & Evinrude Outboards 15 August 27th, 2006 08:38 PM
Evinrude main fuse problem Ace18 Johnson & Evinrude Outboards 1 September 8th, 2005 01:47 PM
Solenoid? Fuse? Neutral Saftey Switch? Brad K Mercury & Mariner Outboards 2 June 17th, 2004 07:43 PM
1973 50hp evinrude fuse problem? HELP!!! wikelam Johnson & Evinrude Outboards 7 July 1st, 2003 04:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
