Re: 704 control box buzzer alarm
on the 704 the actual buzzer is located on the backside of the switch panal if yamaha rigging was used.
to test the actual buzzer simply use 12 v at the buzzer,positive on the yellow buzzer lead and negative on the white with both leads dissconected from the harness.
to test the actual overheat or oil sensor circuit system you will need some resistors and the service manual as the ECU looks for certian criteria to be met BEFORE it wil set the buzzer.
simply shorting a sensor to ground wont work.
a quick test to simply check the circuits on the 07 F150 can be as simple as unplugging the water detect leads at the engine fuel filter and jumping the pins on the engine harness side with the engine idling in nuetral.
