  #1
Old March 17th, 2009, 04:55 PM
bankerjohn's Avatar
bankerjohn bankerjohn is offline
Default 1996 Evinrude 9.9 Flywheel Question - ANSWERED!
Quick question ... what size are the 3 holes in the flywheel for attaching a puller?
I want to be sure the puller set I purchase comes with the correct grade 8 bolts!
Edit: I think they are 1/4"-20 ... or 5/16"-18 ...
  #2
Old March 18th, 2009, 04:46 PM
JB's Avatar
JB JB is offline
Default Re: 1996 Evinrude 9.9 Flywheel Question
I would guess the same, John, but I don't know.
Let's go back to the top and see who does know.
__________________
RED SKY at night. . .
JB
  #3
Old March 18th, 2009, 06:48 PM
Rick. Rick. is offline
7o's and 80's years are 1/4 so I would guess 96 would be the same. Rick.
  #4
Old March 30th, 2009, 05:10 PM
bankerjohn's Avatar
Tried some 1/4"-20 bolts in the flywheel, and they are too small ... must be 5/16"-18 bolts are the correct ones. Back to the hardware store!
  #5
Old March 31st, 2009, 04:42 PM
bankerjohn's Avatar
OK ... so now I've got both 5/16"-18 and 5/16"-24 bolts ... but I can't tell which one to use because I can't screw either size in with my hand (presumably because the flywheel has never been off, and the threads still have paint in them, making even the correct size a tight fit!).
I don't want to risk messing up the threads in the flywheel by trying to screw in the wrong size ... HELP!!!
  #6
Old April 1st, 2009, 07:24 PM
mnmx3 mnmx3 is offline
Well, I read on this forum somewhere that someone couldn't get his flywheel off with the factory size bolt so he ended up drilling the holes larger and tapping them and he was able to use a larger bolt to pop that thing off. If it was me, I would slowly work the 5/16 - 18 with a wrench, going back and forth a little at a time and see what happens. If the threads get torn up you can do the drill/tap thing.
  #7
Old April 1st, 2009, 07:39 PM
Tim Frank Tim Frank is offline
Before you try threading in a bolt, try a 17/64 drill.
It is in between the tap drill size for a NC and NF thread (5/16")
If it doesn't go into the hole, use the NC tap, if it does, use the NF.
  #8
Old April 1st, 2009, 07:42 PM
steelespike steelespike is offline
Is It possible they could be fine thread.5/16 X 24 ,I think.
  #9
Old April 2nd, 2009, 12:23 AM
bankerjohn's Avatar
I went to the hardware store and took my new flywheel with me ... to try metric 8mm bolts. Tried both M8-1.25 (coarse) and M8-1.00 (fine) and neither screwed in any further than the 5/16"-18 and the 5/16"-24 bolts did.
If I'm not mistaken, the motor was made for Evinrude by Suzuki ... so I'm now leaning toward a metric size.
I guess I'm going to have to break down and visit my l local Evinrude dealer, just to be 100% sure I have the right size ... surely they will know what to use!
  #10
Old April 4th, 2009, 06:39 PM
bankerjohn's Avatar
Default Re: 1996 Evinrude 9.9 Flywheel Question - ANSWERED!
The correct size is 5/15"-24 ... flywheel off, electric start kit installed ... tested and working like a champ! Now my wife can start the motor ....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 evinrude 115 question stilesn Johnson & Evinrude Outboards 1 April 8th, 2008 10:38 AM
1996 Evinrude starter question rkaib Johnson & Evinrude Outboards 6 March 2nd, 2006 06:43 AM
Evinrude flywheel balance question John Bett Johnson & Evinrude Outboards 3 March 5th, 2005 01:33 PM
'89 Evinrude 225 Flywheel Question phlyonwall Johnson & Evinrude Outboards 2 September 12th, 2004 06:10 PM
88 Evinrude 1996 Question jeff7599 Johnson & Evinrude Outboards 2 March 26th, 2003 07:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
