Volvo Penta AQ125 timing belt replacement
humphreyb
Im heading upto my houseboat on Lake Eildon on the weekend to service the engine (Volvo Penta AQ125) and replace the timing belt. Does anyone know if I need to pull the harmonic balancer of the front of the crankshaft to get the belt over it? Also is there a timing belt cover as such that I need to remove? I cant remember what the front of the engine layout is in my head. Thanks in advance for any help. Leigh.
Don S
Re: Volvo Penta AQ125 timing belt replacement
Without a manual, the chances of you getting the timing belt changed and the engine running are about ZERO.
So go to the link below and download the manual. Read it.
http://www.4shared.com/account/file/55815583/fad4e100/AQ125145_AB_Service_Manual.html
The pulleys can NOT be all rusty and the tensioner must spin smoothly. If not, you will be replacing the belt again soon. Take your timing light, you will have to retime it.
humphreyb
Thanks Don, will take timing light, your a champ!
Dunaruna
Liegh, I'm also heading up to eildon this weekend (in about an hour actually). What marina are you in?
