My 90hp Mariner is driving me crazy. The engine starts and runs well when running at higher rpm. At slow idle speed the priming bulb must be squeezed every several minutes to keep the motor running. I have performed the following and have the same problem:
checked the fuel tank vent for blockage
replaced the primary fuel filter (fuel/water separator)
replaced fuel line and priming bulb from primary filter to engine adapter
replaced the small see-through filter on the side of the engine
checked all fuel line connections on engine for good seal
I do see bubbles in the small engine mounted filter when the engine is running. I assume air is getting into the system somewhere!
I would greatly appreciate any additional non-invasive things I can do to identify & correct this problem.
my email is: bhwoodside@yahoo.com
Bill
Bill
