I've got a 16' Lund WC short transom, aluminum fishing boat. It's got a Suzuki 15hp 2 stroke, long shaft engine with a 3 gallon gas tank. I'm trying to get the most speed and power out of this set up as I can and need some ideas or guidance.
I figure the boat, engine, gas, and battery weigh right about 500 pounds. The engine has the stock propeller which is a 9.25 x 10.
When I got the boat it seemed like there was a lot of drag on the LS engine and short transom. I had a riser plate built to lift the engine a total of 6 inches. The cavitation plate is now directly inline with the bottom of the boat and it tracks and runs smoother than ever.
With just me in the boat, it will do a maximum of 22.5 mph (GPS) which is very acceptable according to an online calculator.
My question is, when there are 3 people in the boat, it will only do a maximum of 15.2 mph. This seems extremely doggish knowing the potential of the engine. If i went to say a 9 pitch prop, would my top speed be greater than 15.2 with 3 people in the boat or would it just get up on plain faster? With all that weight in the boat, it feels like it never gets on plain with the current 9.25 x 10 prop. Or, would a whale tail cavitation plate be better suited? I'm open to any comments. At this point I'd just like the boat to be consistant whether there be 1 or 3 guys in the boat.
