  #1
Old March 14th, 2009, 02:43 PM
maverickhpx maverickhpx is offline
Default Replacing water pump/impeller on Yamaha F40 2005
I've got the four side bolts off and the on at the rear of the lower unit, can't seem to break the seal to drop lower unit, any ideas on how to do this without causing damage? also are there any major problems to watch for with this procedure, this is my first time. Pete
  #2
Old March 15th, 2009, 12:59 PM
bobby541 bobby541 is offline
Default Re: Replacing water pump/impeller on Yamaha F40 2005
There is another bolt under the trim tab. This will allow the lower unit to drop only about 3/4" as you still have to loosen the connecting nut to the shift rod which is located along the leading edge of the lower unit. This connecting nut holds the upper shift rod and the lower shift rod which are threaded. There is a lock nut on the top of the connecting nut. I would leave one of the four bolts you recently took out slightly threaded in so the whole lower unit just doesn't drop when you loosen the connecting nut.
The lock nut on top takes a 10mm wrench (I used the thinnest wrench in my tool box) and the connecting nut takes a 12mm wrench. You'll have to put both on at the same time to get the lock nut loosened. Make sure the outboard is in neutral as you'll want both the lower unit and the shifter in neutral when you assemble them back together.
once the lock nut is loosened (about 4-5 turns) loosened the connecting nut up until it separates from the threaded lower shift rod. I keep track of how many turns and try to turn the same when re-connecting the connector nut back on.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing Pump Impeller mattdd Yamaha & Suzuki Outboards 1 October 31st, 2007 06:32 PM
Replacing water impeller on 87 merc 70hp bagman2 Mercury & Mariner Outboards 5 May 1st, 2006 05:19 PM
Torque required to spin water pump shaft when replacing Cobra water pump? lakelivin Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 April 13th, 2005 09:06 AM
Replace water pump impeller only or install complete water pump Kit? Jonathan Burnett Johnson & Evinrude Outboards 9 December 9th, 2003 09:27 AM
replacing water impeller in alpha 1 out drive derfisin1977 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 1st, 2003 01:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
