Does anybody know if the DVD and CD drivers are on the Windows Installation disk or on the Drivers and Utilities disk for a Dell computer.
Thanks for anybody's help.
Dell's come with a "restore" CD but they require a full re-install of everything. You are better off finding who made the drive and going to their site for drivers and software.
Generic drivers are usually on the Windows install disk. Usually Dell has an all in one disk that installs everything OS and drivers, did you buy a new drive or just have to reinstall the old one?
I was referring to the installation disk. My Dell Dimention 9100 computer crashed and I got everything back up and running but the DVD and CD Rom's will not operate. I went through Systems, Device drivers and the computer recognizes them as being installed but there is no software installed. As stated above Dell does not offer a dowload fix and i don't want to re-install windows as I would have to reload all my personal data and programs again. So everything works fine except the DVD and CD Roms. I have a CD marked Drivers and Utilities but I didn't think that was the CD with the DVD drivers on it. It will only run by booting up to it. Of course the DVD won't run anyway. That is the problem. Thanks everyone for your help. I guess I'll just have to take it to a Computer shop and let them install the drivers off my Windows XP installation CD so I don't lose everything.I know there is a way to install only the missing software. I just don't know how to do it. I do have most of my stuff backed up on 250 MGB Zip Disks just in case. About 20 of them and I do have all my program Installation CD's. Thanks again.
Are you saying the drives won't read a disc at all while in Windows?
Have you checked the device manager to see if the drive is missing or if it has a yellow exclamation point? You really shouldn't have to install any software to be able to read a disk. You should only need that to burn discs or watch a DVD movie (which I forgot to mention).
Yes the drives won't work. They both have the yellow marks, Scan says no software I tried everything. Update drivers, search the web for drivers. There are about four options and nothing works in Device Manager. I had a program I wanted to install (Paperport) and the drives wouldn't work. That's how I discovered the software drivers were missing. The computers finds new hardware when I restart or boot up in the morning.
Have you tried deleting the drives with the yellow exclamation points then rebooting?
cbavier,
hello I had the same problem,I found help on google printed it out I will see if I can scan it and send it to you if you give me an email addy.
woosterken
you can access my email through my personal profile. If you can't find it in my profile, woosterkin submit another post on this forum and I'll post my email address. Thanks and yes I deleted the drives and then rebooted from the installation CD and got lost. I guess after it went so far I didn't know what to do next. I was afraid to go any further so I exited the set up.
If you have anything in device manager under "Other" be sure and remove whatever you find there as well before you try to reinstall anything by rebooting and letting the system detect your hardware.There should be no item named "other" and flagged yellow in Device Manager.Ron G
Describe crash....and describe what you did to when you "got everything back up and running " (briefly)
As i386 mentioned, the upper and lower filters entry in your registry could be the problem. It usually happens when you install a cdrom burning program and it's drivers, that things get hosed and you loose your cdroms etc. Error codes 41 and 37 are the result.
The fix is to edit your registry in a couple of places. If manually editing the registry is a new thing, a word of caution, messing with the registry can render your computer unable to be booted etc. With that in mind, you can run a small file that will do the edits for you with the same -safe-result.
Here's a link to a zip file that has what is needed...
http://aumha.org/downloads/cdgone.zip
The usage is to open the zip and run the cdgone.reg file
You'll be asked if you want to merge the file into your registry, say yes. Then reboot and see if your cdrom/dvd work.
The next option is to delete or uninstall the IDE ATA/ATAPI Controller in device manager and reboot. Windows will redetect the controller and install the drivers for it.
Example: In your device manager find:
IDE ATA/ATAPI CONTROLLERS
clicking the plus sign and this is the following list:
1- Intel(r) 82801aa Bus Masters IDE Controller (yours may be different)
2- Primary IDE Channel
3- Secondary IDE Channel
In this case, "Uninstall" the Intel(r) 82801aa Bus Masters IDE Controller.
Next, Shut Down(Reboot your computer)
