Silver Heels
- Apr 28, 2008
- 125
Hello,
Well, the past owner of my boat didn't do me any favors. He told me the wood in the transom was recently replaced. A year into owning the boat, I begin seeing small, powdery pinholes popping through the aluminum transom (boat is a 1989 20' Mirrocraft Voyageur). Searching for answers as to why, I stumbled upon this site and discovered the PO used pressure treated plywood against the aluminum. Repeat after me..."DON'T USE TREATED WOOD IN AN ALUMINUM BOAT." The old wood came out (stubbornly, as the wood and aluminum corroded themselves together), and I just picked up two 3/4 in sheets of marine ply, ordered through Menards for $60 ea. I have also taken this opportunity to install some Bennett trim tabs and clean up what was once a rat's nest of wiring buried deep within the bowels of this vessel. With all the pumps, lights, trimtabs, etc, I have a bunch of ground wires to connect. The previous owner had a million ground wires going right to the battery, so I fabricated a bus bar out of stainless screws tapped into a small piece of 3/8 aluminum with a single cable going to the neg battery post. This bus bar was, in turn, screwed to the underside of the aluminum splash well. A good idea, or so I thought until someone pointed out I might cause further corrosion by having the battery grounded to the hull. Should I redo my setup or keep on truckin'? The boat is used in freshwater and spends most days up on the trailer.
