Where would I find this tool
BarryT
Clutch plate alignment tool (C-91-57795) Haven't found it anywhere. I might need it when I put a new motor in.
-barry
WizeOne
Re: Where would I find this tool
-barry
There is no clutch plate to align in your engine/outdrive???
BarryT
I have a mercruiser 215E drive. My manual says it does. My father inlaw says its an electronic shift and from my last thread about my belt driven raw water pump I identified my drive as a 215E. Witch has a clutch. Unless I am wrong about the drive model. I have a 215hp Mercruiser. It has a belt driven raw water pump mounted on the engine. The drive itself does not have a water pump in it. I think that makes it a 215e. Also my drive says 215 on the side.
-barry
Ayuh,....
Wizeone,... Barry has the 215E,... A true Classic that was only built for a couple of years, in limited #s....
This is Not your usual 302/ Mod.1 drive...
Barry,... Have you even found a Picture of these Special Tools....
My Guess is,..
You're going to have to Build your own Tools,+ probably some Parts if you wanta keep running this thng....
BarryT
Thats what I have heard. Well the clutch plate alignment tool looks just like the ones you would use on a car when doing a clutch change on a manual transmission. Maybe I properly taperd wooden dowel will work. Hopefully I dont need it. The manual says I will need it if the electronic shift is engaged witht he drive off. That should not happen. I have done some searching and I can find bearings but no seals and no major parts. I guess if the drive has a critical failure then I would have to replace it with one that bolts up to my 302 motor.
-barry
WizeOne
Ayuh,....
Shame on me for jumping to conclusions!:redface:
krisnowicki
do you have any pictures of your setup? It would be nice to see this mystery drive...
BarryT
I will be off of work tomorrow and will take pics if I can get through the snow
-barry
slasmith1
I would look in don's tool box.
starsnstripers
WOW, Thats quite the set up. I was just looking at it in My manual. It doesnt show the end of the shaft, it only shows the shaft and plate inserted. Maybe could use a fabricated shaft with pilot and spline mesurements. I'd try it. good luck.
