Someone just gave me this motor. It is model 2602S. What does the model number stand for?
I was told that it hasn't been started for about 7 years. The needle valves looked clean. I didn't take the carb apart. Should I just put gas in it and try to run it? (The spark plug fires.)
The lowere unit doesn't have a drain plug. Do I assume the lower end is OK? There is no sign of leakage.
To whoever answers: Thank you very much for your input.
