Quote:
Finally, is there anything else I should be looking for?
In addition to checking compression, it is a good idea to check for a strong spark on all cylinders (using a spark tester) and checking for a leak in the lower unit oil seals (by draining a bit out and looking for a water or milky looking oil coming out). There a other things that can be checked but these three would be the minimum in my opinion.
