Markystang
- Jan 7, 2009
- 5
I'm new here, and I've got an interesting problem with a new-to-me Yamaha 115ETLH. You'll have to bear with me. Besides basic mechanical knowledge, I really know next to nothing about outboards.
The boat had been parked for the past year, and birds had nested under the "hood" of the engine. So I brought it in and cleaned it up real well with compressed air and a shop vac.
With the intention of running it, today I pulled all the plugs, cleaned them up a bit, sprayed a bit of oil in each cylinder, put the plugs back in, pumped the bulb, put the water muffs on it, and hit the starter. It fired right away, but wouldn't stay running for more than a couple seconds, then wouldn't restart. I'd repeat the procedure,(clean plugs, oil cylinders, etc.) and it would run again for a couple seconds.
I noticed no water coming out the "pee hole"...lots coming out holes in the lower end, but none up top. At first I had thought it would come out when the engine was running once it pumped it up. But it didn't. A bit of investigating, and I noticed the pee hole was plugged. I pulled the hose off it, and right away had water pour out. I cleaned the pee hole and put the hose back on it.
Trying to fire it again, I noticed water leaking out the front plastic cover over the carbs. I pulled the cover off, and sure enough, there seems to be a bit of water coming out around the choke butterflies...wtf?!?
Pulling the plugs again is showing "milkshake" on the plugs, indicating water mixed with oil/fuel.
So how is water getting into the engine? Is it possible the plugged pee hole has caused a gasket somewhere to blow out? If so, where?
Any ideas are appreciated! Again, bear in mind I really don't know much about this so use small words with me...lol.
Thanks!
-Mark
Thanks!
-Mark
