350 crusader vs Merc
cantaris
Can a chevy 350 crusader engine that has brass manifolds.coolers etc be used with a mercuiser outdrive? Or do you have to change out the manifolds?
Re: 350 crusader vs Merc
Ayuh,....
I'm absolutely Positive there'll be fitment issues Galore in that Swap....
cantaris
Thanks Bond-O. That is what I figured. Guy had two chevy 350 crusaders for $500 for the pair.
krisnowicki
I did a transplant with a crusader power pack engine which is made as a direct replacement for merc. If it is those there wont be that many problems at all if they are the same vintage. The one I got was basically a bolt in replacement for my merc.
Like this one
http://www.crusaderengines.com/powerpack.html
