Hello everyone,
Please let me say thank you for all of the information on here as I am a new boat owner.
I had trouble with my 1993 60 HP merc jet outboard idling and I noticed that the throttle valves are closed at idle. So I adjusted the linkage to make the just slightly open. Well this has now made it idle ok if not fast. What I am wondering is I have noticed what look like screw in air bleeds on the sides of the carbs next to the idle mixture screws and is this how the engine gets its idle air quantity? I am not new to idle bleeds as I have worked with alot of automotive performance carbs that were equipped with them. And next question is if they are indeed that should I removed them and spray with gumout to clean them?
Thank you again
Michael
Thank you again
Michael
