did i get a good deal or keep looking?
oops!
Re: did i get a good deal or keep looking?
im not framilliar with that market area.......but i can only guess you paid a bit more than full value for that package.....(if you were the winning bidder)
with the econemey in the toilet.....boats start to go cheap.....especially at this time of year
Floatsum
Nice boat.
Don't think much of the trailer though or the way it's set up.
Could be just the pictures though.
D
DJ
Guest
I think it's worth that, if the engine checks out OK.
kandil
Nice boat BTW it is 17'6" and with the Yamaha outboard you will be happy most off the older sea pro came with a Force outboard happy boating and welcome to iboats
tashasdaddy
if it is as clean as it looks, i believe it is worth it. it is what it is a "Fishing Machine" but not a good family cruise boat.
Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame. You walk all over the deck, that a mallot, or hammer with wooden handle, using handle, tap all over the transom, a shape rap is good solid base, a thud, is questionable base.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. (This part for outboard motors Compression should be atleast 100psi, and within 10% of each other,)
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
boat motor combo, A 30 year old may be in better condition, than a 3 year old.
salty87
looks clean and ready to run. there's alot to be said for a previous owner that took great care. compare against prices in your area.
Dave K.
real nice boat!! speaks well of any owner who takes care of their boat & (unless the pics are off) this boat was taken care of.. 90 hp yammi is a plus+++ & clean too.
INJUN
So . . . . . did you get it?
It looks like it'd be a great bay boat.
alfmoney
i did get the boat and it was worth every penny and it was even cleaner then the pics, thanks for all the help.
nightstalker
You got a fair deal, not a steal in this market, but pretty good. $6000 is the going rate for a rig like that now adays.
Nightstalker
