  #1
Old February 28th, 2009, 11:51 PM
al r. al r. is offline
Default Help ! 20 amp fuse blowing on 98' 40 hp mercury
I just purchased this boat & motor 3 days ago I had to bring it to the shop immediately carbs needed repair. now on two occassions last night and today the fuse has blown. The first time as soon as I returned from the shop i tried to start it and nothing, i called the shop nad was told to check the fuse and sure enough blown. 2nd time today first time out with boat it was running fine I stopped to fish and when i went to start nothing , fuse blown again !
  #2
Old March 1st, 2009, 12:09 AM
blackbox blackbox is offline
Default Re: Help ! 20 amp fuse blowing on 98' 40 hp mercury
do you have power trim? is the trim switch in the throtle handle? most blown fuses are from a chafed wire at the control. another area is under the dash-any thing powered up by the "key on" power (purple wire). things like the tac and fuel gauge are examples. if some one just did carb. work chk. for pinched wire harness. dose the fuse blow when you turn the key "on", or, when you push in the"choke"? this should not be hard to pin pont. hope this helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 225 H.O. blowing 20 amp fuse LaveyT Johnson & Evinrude Outboards 2 October 28th, 2008 10:26 AM
2002 115 hp blowing 20 amp fuse npr0520 Mercury & Mariner Outboards 2 June 15th, 2008 12:33 PM
150 1999 Evinrude blowing 20 amp fuse RAYHYAR Johnson & Evinrude Outboards 5 February 13th, 2007 03:51 PM
92 Mercury 40 HP keeps blowing fuse bayou vista 19 Mercury & Mariner Outboards 1 June 1st, 2004 07:34 PM
1995 40 HP Merc Blowing fuse {20 amp} M Mac Mercury & Mariner Outboards 0 June 22nd, 2003 08:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
