Mikey4x4
- Dec 27, 2008
- 6
Hello All
I have a 1980 75 hp. Stinger Johnson J75TRLCSA and am having power problems with it. In drive way with hose cup on, it runs fine, idles, powers up when advancing throtle. It also idles, powers up fine when in gear (forward & reverse). Now the problem! when you put boat in water, idles ok but when you put in gear it boggs out and dies, will not do anything under load. Pull boat out of water, motor idles, powers up fine when in gear (forward & reverse) again. Compression in all 3 cyls is good, I had carbs rebuilt 3 times. Changed out coil and power packs, still same problem. At a loss of ideas!
Mike
EDIT
Mike
EDIT
