Glastron V210
wallybme
First let me intrroduce myself. I am a first time boater, have a Glastron V210 which I own and would be making some repairs to bring it up to seaworthyness. Sad to say I ran on this site earlier, but never thought it had so much to offer.
I am about to post my firs call for help. I need to remove all the old gas from this boat, but do not know how to. I found out that it has an anti siphon valve and wondered if this would not allow me to siphon it out. All help is appreciated.
I just had my engine redone (Mercruiser 898) and do not want to use the old gas. The boat was sitting for over 12 years without any use.:confused:
oops!
Re: Glastron V210
hi......welcome to i boats....
yep.....this forum is the best boat fix it or general info on the net.....
pretty good place if you spend time and get to meet the guys, they are first class.
but how bout if we get this up to the right forum where the guys can see it and help you.....
cheers
oops
Re: Glastron V210
Ayuh,....
The Valve you ask of is the Hose Barb at the tank's outlet...
You can either swap it for a plain ole Hose Barb, or what I prefer, is to attach an electric Fuel Pump to it,+ run the fuel out into another can for disposal...
muc
"Retired" Association of Marine Technicians...
Re: Glastron V210
I have had troubles doing it Bondo's way. The hose barb screws into a dip tube that stops about 1 inch from the bottom of the tank so you are leaving the worst of the gas and any water that might be in the tank. I think a better way is to remove the sending unit. This gives you a big enough hole to suck out everything and also inspect some of the inside of the tank. Make sure you tilt the boat so it all runs to the end of the tank that the sending unit is at. Good Luck Muc
wallybme
Re: NEED HELP
Re: NEED HELP
i AM TRYING TO POST A THREAD, BUT THIS COMES UP ALL THE TIME...WHAT SHOULD I DO????:confused:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
