I have a 1971 55HP Chrysler. When I first got this motor it did not run. The head where the top plug goes in was stripped. I had it rethreaded. I put on a new head gasket and the gasket to the plate that goes over the head. When I did this I knew nothing about torching or sequence in tightenning the head bolts. So I just put it on and tighened them. Later on I realized they had to be torqued. Which I did. Now water is leaking from the top spark plug when I start it. Do I need a new head gasket or do I need the gasket that goes on top of the head under the plate? I saw no water in the cylinder.
